Report bug
Please send us a minimal code showing the bug, with comments inside your code, so we can reproduce the problem and better understand what you found. Please also provide maximum information in the text area below about what you expect and what you have. We will get back to you shortly
Please fill in the information below :
About your request: Please send us a minimal code showing the bug, with comments inside your code, so that we can reproduce the problem and better understand what you found. Please also provide a maximum of information in the text area below about what you expect and what you have. We will get back to you shortly.
